bop R@P identification
Posted: Thu Feb 16, 2012 11:17 pm
by RFraver
I have a 8.2 bop (Best as I can tell ) and would like to know what it fits. Its a 27 spline (Pinion) rh thread ringgear bolts, the pinion tapers towards the splines with the big end being somewhere near 1.900" The part#'s are 1382743 42-13 gmc (Ring) and 1384201 13-42gm (Pinion) I've had it for years and in says "Pontiac" in sharpie in the back of the pinion. Any ideas?
Re: bop R@P identification
Posted: Fri Feb 17, 2012 12:08 pm
Send some pictures Might be 1.875 on the shaft. ARE you sure it si 27 spline? If so it is a odd ball 68-70 BUICK 8.2 ONLY - you can not use it on anything else IF it has 12 ring gear bolts it is a 9.3 pontiac / olds gear set But that would be the wrong pinion spline...SO we really need to get better info for ISD and some pictures too.
What is the diameter of the ring 8.2 8.5 8.75 8.875 9.3??? How many bolt holes in the ring and double check that spline count.
Posted: Fri Feb 17, 2012 10:12 pm
by RFraver
Yep, 27 spline pinion. Where do you measure the ringgear? On the backside, the diameter of the flatside is 7 7/8". 10 bolts hold it on.
Posted: Sat Feb 18, 2012 3:52 pm
Complete diameter outer to outer most point.
Sure appears to be a 68-70 buick 8.2 10 bolt rear end gear set. WILL NOT FIT A PONTIAC 10 BOLT 8.2 OR ANY OTHER 8.2 FOR THAT MATTER. Only Buick 10 bolt 8.2 from 68-70. 3 year run rear.
WHat are you doing with it?
you can call 330 990 8155 if you need.
Posted: Fri Feb 24, 2012 7:34 am
by RFraver
8.5 is what it measures at widest point. I have a auburn carrier (8.2) the it fits right over and the 10 bolts line up perfectly. Any thoughts?
Posted: Fri Feb 24, 2012 7:05 pm
Yes probably 10 bolt 8.2 Buick ONLY 68-70. Jim
