Mix & match 8.5 parts
Posted: Wed Aug 10, 2011 8:35 am
I have a 3.42 gear set and posi unit from a 91 Caprice (police). It has the ABS sensor "gear" on the pinion shaft. It has 30 spline side gears and 30 spline pinion. The original installation used C clips.
I have a 71 Buick 8.5 housing with bolt-in flanges. It was originally a 2.56 open unit . I want to install the 91 setup into the 71 housing. A trial fit shows that it installs easily. This will be used in a 67 GS 400 with a mild build 455 (Stage 1), street only.
Are the carrier and pinion bearings/seals the same for this housing and the 91 setup - I didn't disassemble all the pieces but the items I could measure all seem to be the same?
Can you get axle shafts for me that use the 71 bolt-in bearings/seals, 5 on 4 3/4 stud pattern, and have the 30 spline ends on them?
Thanks for any info.
