bearing question
Posted: Thu May 05, 2011 6:48 am
72 Buick
Question... The race shown in the picture is loose inside the axle tube. what I suspect it is the outer ring of the tapered axle bearing. Is this true? Here's why I had to take it apart. Only about a 1/4 of axle was engaged. that's a 1/4 inch from the end of the axle so even less of the actual spline was connected.
