Check my gear pattern pics
Posted: Thu Apr 28, 2011 9:00 pm
by 67drake
I'll just copy and paste my other thread. It takes me about 15 minutes to load these photos otherwise!
Pics here-
http://forums.performanceyears.com/foru ... p?t=664838
Re: Check my gear pattern pics
Posted: Fri Apr 29, 2011 6:40 am
wow, oK that is fine, HArd to tell as you need more oil and more turns to get a better pattern. Do not hesitate to really spin that ring round and round and round.
Posted: Fri Apr 29, 2011 9:26 am
by 67drake
Posted: Fri Apr 29, 2011 11:17 am
Yes the coast side is USUALLY what you go off of on the used gears and yours appears to be a bit deep try .039 ish area Iand I bet you will be dead on. Jim
.009 .010 backlash for checking if you can.
Take care, Jim
Posted: Sat Apr 30, 2011 9:07 pm
by 67drake
Posted: Sun May 01, 2011 9:25 pm
For good used set of gears I say go with it. Do your final assembly and double check everything. If it looks good after that. Button the cover up full it and RUN IT. Let us know how it turns out. JIm
Posted: Thu Aug 04, 2011 4:30 pm
by 67drake
Just wanted you to know everything came out fine.
I got my shortened driveshaft back today from the shop,then buttoned everything up after setting pinion angle. No noise or vibrations.
Thanks for all the help Jim! I've sent quite a few guys your way when they are looking for rear end or gear help.
Posted: Fri Aug 05, 2011 8:13 pm
HE HE-- Excellent for you. After all that I am really glad you got it right.
Enjoy the rear and the rest of the summer.
Take care and thanks...
