8.2 posi need help
Posted: Wed Apr 27, 2011 7:24 pm
by rustydeeretech
i have a 1970 buick gs 455 with the 8.2? no c clips and driver side bearing is bigger than passenger side it had an open diff till i broke the spider gear pin i bought i limited slip from jeggs 540299 auburn pro for it the bearings that came with it were both the same size and the bolt holes were 3/8 inch where the factory bolts were 7/16 but found it just doesnt fit right in the carrier was wondering it you have heard of this and what i can do o get rid of my ped leg thanks for any help neal
Re: 8.2 posi need help
Posted: Fri Apr 29, 2011 6:47 am
YES, Well we specialize in your 68-70 BUICK ONLY rear diff.
There are only 2 aftermarket sets for your rear 3.42 and 3.64. We pretty much sell them exclusively and provide great tech help on ALL rear end work.
First we need to know what ratio you are working with in your diff? 2.56 2.73 2.93 3.23 3.42 3.64 3.90 or higher.
THEN we can start to guide you through.
The carrier you received is a PONTIAC carrier...Jegs and Summit are NOT differential experts so they can only go by what you tell them you need.
We have aftermarket carriers that cover the 2.56 2.73 2.93
we have aftermarket carrier that covers 3.23 3.42
We also can MODIFY a aftermarket carrier for the Original 3.64 3.90 and steeper gear also.
Start with step one WE NEED THE gear ratio.
Thanks and hope to help.
Posted: Sun May 01, 2011 6:27 pm
by rustydeeretech
ok i have the stock 2.93. i beleve you did some work on my buddies 440 dodge dart rearend and would like to inquire about you doing some work on mine as well im located in chardon oh my number is 4402260712 thank you neal
Posted: Sun May 01, 2011 8:57 pm
by 67drake
Monzaz (Jim) # is 330 659 7117
