8.5 for '68 Camaro
Posted: Thu May 13, 2010 12:55 pm
Great forum. Very educational…
I have a '68 Camaro convertible with a stock 8.2 rear and 2.73 gears. I'm looking to replace the entire rear end unit with an 8.5. I know I want either 3.43 or 3.55 gears with posi. Ideally I'd like to get the full assembly (brake set up and all) so it's basically a bolt in process. I wouldn't be starting this project until the fall so I do have some time...
A few questions:
- What would be the approx cost for such a set up?
- I don't want to shorten the current driveshaft that's on the car if I don't have to. Is that a problem?
- Any 8.5 I got from you for my Camaro would have multi leaf spring perches correct?
- How do you finish the housings?? Paint, powder coat??
Thanks!! Many more questions to follow…I'm sure of it...
A few questions:
