Chevelle 12 Bolt Identification and Application Question
Posted: Mon May 10, 2010 8:40 pm
Hi Jim:
A seller has advertised this rear end as follows-"This a 71 SS 12 Bolt 3.31 Posi rear axle. Code on right axle tube is CFC 133 2E. Casting date of center section is D 7 1. Build was approximately May 13th 1971 (133rd day, 2nd shift). Gears still look good and it operates smoothly. Posi tag and factory plug are still intact".
Would this be a good candidate for my 72 Chevelle 'vert with an LS1 stock with a 4L60E? And what would you check or be looking for with this particular rear end if I end up checking it out? Thanks.
Chris
Chris
