8.5 carrier interchange
Posted: Fri Mar 05, 2010 10:23 am
I have a 71' or 72' 10 bolt corporate 8.5 rear with a 2 series posi carrier. I run a spacer behind the ring gear of my 3.42 gear. I have the chance to pick up a rear with a 3 series posi from a 79' Camaro. Will the carriers interchange? I understand that some 8.5's had c-clip axles,but are the carries different between the c-clip rears and bolt on axle rears? Will the axle spline count be the same too? Is there a list or rule of thumb as far as 8.5 carrier interchange?
Thanks!
Thanks!
