BUICK FULL SIZE REARS WITH 10 BOLTY 8.5 CENTER AVAILABLE NOW
OK, HERE is the first of hopefully many Buick rears... This one is a 1967 Riviera 10 bolt 8.5 3.73 posi .
These rears are direct bolt in width is same all mount brackets and points stock locations
Stock backing plates and brakes, keep all the stock looks with ALL the NEW technology of posi units FULL spools and MANY gear choices from 2.41-5.57 including everything in between 3.08 3.23, 3.42, 3.73, 3.90, 4.10, 4.56, 4.88
Rear end also keeps the factory HUGE axle shafts because THEY ARE STRONG! period. Bolt in axles idea for high performance applications
One mod needed is a u-joint conversion all depends on what differential yoke your rear diff has currently...We will help guide with that though. :)
So there you have it... who wants to be the Ginnie pig...lol
COMING SOON OLDS AND PONTIAC 65-70 REAR ALSO... USING FORD 8.8 CENTERS
