Gears for my Type "O" Olds rearend??
Posted: Sun Jan 31, 2010 1:50 pm
I have a Type O , 31 spline, carrier casting 672 from my 1967 442 currently with 3.42 gears.
My first and main question is trying to find out if there are any R&P sets available for this unit in the range of 3.90 - 4.33?
In reading the sites info and stuff for sale, it appears as though there isnt any gearsets of these ratios available for my housing?
If this is correct, then I must look for another housing because i want to have a ratio somewhere btween 3.90-4.33.
I do also own a Type P 3.08 Posi rear (2 converging webs in centersection) housing from another 67 cutlass that i bought as a parts car. Its laying in back of shop with thought of using if i wanted to switch to my car to a "road" gear.
It appears from reading on your site that there IS the lower gears available for this type P, but that the type P is a much weaker rear than the "O"??
I am going to use this rear in my restored 67 W30 car that will be a street/strip W-machine with modified 400 +.060 Big Block Olds with a lot of torque that should do 1/4 mile in low 12's (TH 400 w/ 3500 stall).
What do you suggest if I cant get gears for my type "O"?? Back "in the day" when i raced the car (67-70) i put a 12 bolt type C Chevelle housing under it with 4.56. I was told at the time that i would "shell" the stock W30 Type P with the cone-type posi because it wasnt nearly as strong as the 12-bold chevy. The 12-bolt chevy never lost a gearset in it the entire time i raced it!!
Thanks for listening and giving me some advise.
