Bent axle?
Posted: Fri Nov 27, 2009 12:20 pm
I'm trying to figure out where a vibration is coming from. 1970 GTO, noticed vibration from rear after reassembling car and installing 3.55 posi unit that I got from you about a year ago. Balanced and rebalanced rear tires, swapped fronts to rear, had u-joints replaced and driveshaft balanced. Now if I lift rear and run up to speed I notice the right rear has noticable runout. Do you think the axle is bent? If I pull the axle and check it what is the acceptable runout?
Mike
Mike
