Need HELP on 10 bolt I.D.
Posted: Sun May 10, 2009 6:19 am
I've been sent here from ClassicOldsmobiles.com. This is currently in 67 442. It is a posi/limited slip, which is what it was supposed to have had. It has a leaking pinion, and I was trying to I.D. so I could get correct seal and try to replace it myself. Based on the rust appearance not matching the rest of the car, the cover isn't like other Olds that I've seen in pics and that it seems to have red paint on at least a portion of it at some point, I'd assume it has been a swap out.
Some have said Olds put Chev. rear ends near end of runs, and this was a fairly late date 67, but others have said "NO WAY" on that one. I have tried to match the cover with your I.D. pages, but can't find anything with the 'half eye brow'.
I noticed on some recent posts, people have supplied pics of the top of the casting, which I can try to get if I need to. Thanks for any help.
D
D
