10 bolt monza
Posted: Wed Apr 15, 2009 11:15 am
by David F Adamski
Jim/Monzaz-saw a recent post on the H-body forum; Bill K thanked you for his 2.93 to3.73 swap; that is exactly what I would like to do with my 75 Monza (SBC406,th400,2.93 posi,BFG drag radials managed a 12.20@115mph while racing it this past summer-go into third about a bus length from the traps); how about a price quote and mailing address,I'll be sending a postal money order,for your bearing kit-I would/could have the pinion turned down here in Kalamazoo-OR,pay you for the complete package-ring@pinion (machined), bearings,seals,races,ect. and I would only need Moser to cut 28-splines into a set of monza axles drilled for 5 lugs. Really appreciate your sharing of knowledge and the time spent answering questions-Thanks again. David, in Kzoo,Mi 2693422957
Re: 10 bolt monza
Posted: Thu Apr 16, 2009 9:15 pm
David, I will call you tomorrow as we need to talk alittle about some of the thought you have. Hang tight I will call tomorrow. Jim
Re: 10 bolt monza
Posted: Fri Apr 17, 2009 1:17 pm
by David F Adamski
Hey Jim-saw your post from the 16th, I'm stuck at work til 7p,get home by 8-or, I'll be home this weekend,would like to here from you, David (work #269 788 0496,ask for the nurse)
Re: 10 bolt monza
Posted: Fri Apr 17, 2009 9:10 pm
Ok I will call saturday then...lol. We will get hooked up. Jim
Re: 10 bolt monza
Posted: Fri May 08, 2009 4:13 pm
by David F Adamski
Hey Jim, while finishing my "list" for you, having trouble finding a minispool for a 10bolt,7,5,28 spline axle rearend and with further diggin',doesn't look like there is a Detroitlocker Truetrac for the 28spline-7.5. any ideas/resources?? David in Kazoo
Re: 10 bolt monza
Posted: Thu May 14, 2009 10:04 pm
Detroit true trac...NO locker in that title. Detroit locker will be a totally different beast all together.
Re: 10 bolt monza
Posted: Thu May 14, 2009 10:05 pm
Detroit locker 28 spline is 539.00 OUCH. Probably not really worth all that and is noisy too.
