Help reading this gear setting
Posted: Sun Apr 05, 2009 2:31 pm
BOP 10 bolt with 3.36 and new Eaton Posi.
I am starting to put my rear together. I started with .030" on the Pinion shims and tightened the pinion so it has ~ 24 In/lb preload.
I have the carrier installed and a backlash that is varying from .005 to .008 around different reading points. So I gooped up the ring gear in two places, 180 degrees apart and rotated it back and forth.
I am going to try and attach 4 photos, 2 of each point on the ring gear, drive and coast sides. Can you confirm what I think I need to do here. Initially I think I need to remove a few thousandths from the pinion shims.
Any insight will be appreciated.
