12 BOLT S-10 STREET STRIP REAR DIFFERENTIALS
Posted: Wed Dec 17, 2008 10:39 am
12 BOLT REAR DIFFERENTIALS ARE AVAILABLE FOR ANY 2WD DRIVE S-10 APPLICATION WITH NO MODIFICATIONS TO THE DRIVE LINE.
USES THE SAME LENGTH DRIVE SAFE
USES THE SAME U-JOINT
USES YOUR SAME LEAF SPRINGS
USE YOUR SAME U-BOLTS AND HARDWARE
USE YOUR SAME DRUMS AND BRAKE ALSO (WHEEL CYLINDER MAYBE THE ONLY MOD DEPENDING ON THE YEAR OF THE S-10)
ASK QUESTIONS...
Re: 12 BOLT S-10 STREET STRIP REAR DIFFERENTIALS
Posted: Wed Aug 11, 2010 11:35 pm
by ketel22
Is this differential still available? is it housing only? any options, what pricing goes with this? TIA
Posted: Thu Aug 12, 2010 2:20 am
These are always available.
we can build a 12 bolt truck or car centered s-10 rear or 8.8 ford and or 8.5 10 bolt which is what we race with under our vehicle. 11.40 bracket racer.
12 bolt car will be more expensive as we have to take a chevelle, camaro or other car housing to make your s-10 rear from.
It is always best we get more info as to what you use your truck for (application) then we can fit you with the right product for your needs cost and strength wise.
12 bolt Car center cheapest would be 1200.00 (housing harder to find usually Muscle rears)
12 bolt truck center s-10 direct bolt in 899.00 cheapest form (housing easier to find)
10 bolt 8.8 or 8.5 center would be 799.00
These are complete rears WITH NO BRAKES and usually mini spool FULL locked differential Usually your gear choice new bearings.
Like i said it is best to CAll and discuss your exact needs and we can throw some REAL time quotes for you. We do have specials from time to time on pre built rears.
Still have one 8.8 with 4.10 and mini spooled direct fit 2wd s-10 for 799.00 Includes backing plates also 5 lug on standard GM 4 3/4" bolt pattern.
330 659 7117.
Posted: Thu Aug 12, 2010 11:35 pm
by ketel22
thanks for the reply, i will have to contact you when i have more free time during normal hours of operation.
Posted: Sun Aug 15, 2010 5:48 pm
by ketel22
will you sell the bare housing? cut to length with perches?
Posted: Mon Aug 16, 2010 12:56 pm
Yes, What size rear diff were you looking into 12 bolt truck or 12 bolt car...Big difference in price as truck housings are easier to come by than the car ones.
Posted: Mon Aug 16, 2010 11:30 pm
by ketel22
sorry im unable to call during business hours to get these answers. I'm looking for a rear to put into my dd s10 that ill be installing a 500hp sbc into. i know the stock 10 bolt will not hold up, and i know that there will be room to expand with a 12bolt. i was hoping to get something with decent axels a posi-traction and most likely 3.73 gears, disc breaks and a 4 link. I know your housing comes with the stock spring perches and thats a good reference for me to do my 4 link off of. so i guess if you could price me a bare 12bolt truck rear cut to length with perches and whatever else it is you do to prepare them for the s10 versus a 12bolt truck rear with 3.73 and posi-traction. thanks.
Posted: Tue Aug 17, 2010 9:47 pm
Phone help from 10am to 10pm weekdays eastern standard time.
I will get you up a quote But still need the email address. Jim
Posted: Wed Aug 18, 2010 2:54 pm
by ketel22
ketel22@hotmail.com
What is the phone number for jdrace?
Posted: Wed Aug 18, 2010 9:32 pm
GAve it already...
330 659 7117
