10 bolt carrier id HELP
uncleg
Post by uncleg »
Can anyone help with an ID of this carrier?
It seems to be an auburn style, but the numbers I found hav'nt been any help.
I would like to rebuild if possible.
10.5 ten bolt 273 up carrier.
numbers that are on the tube. PT G70421
Re: 10 bolt carrier id HELP
That is a Borg Warner 10 bolt (round cover 10.5") 8.5 (ring gear diameter) Limited Slip posi unit
28 spline axle unit and can be used in all 1970 -1987 10 bolt 8.5 rears including bolt in axle or c-clip axle rears.
It is a cone type like Auburn units.
The cone and side gears are 2 separate pieces.
If you say it had 2.73 gears it will have 3 series carrier and will hold all ratios listed
2.73 2.93 3.08 3.23 3.42 3.73 3.90 4.10 4.30 4.56 4.88 5.13 5.38 5.57
