1987 Grand National posi 3.73 rebuiblt rear with new brakes
Postby monzaz » Fri Feb 29, 2008 9:02 am
Here is what I was going to put on ebay.... This was an Original 3.42 GN posi rear but a customer wanted 3.73 new gears and the posi rebuilt all new bearing and brakes...They just disappeared??? 1 year is enough TIME TO SELL. lol.
This is how the auction will read on the BAY: just ask for pictures...SUPER CLEAN HOUSING.
starting price was going to be 1495.00
UP FOR AUCTION
ORIGINAL GM
GRAND NATIONAL POSI REAR DIFFERENTIAL
SPECS
10 BOLT GM ORIGINAL GN/442 HOUSING LARGE 10 BOLT 8.5(MEDIA BLASTED PRIMED AND PAINTED)
REAR CLEANED OUT (AXLE TUBES CENTER SECTION EVERYTHING)
ORIGINAL FACTORY GN POSI UNIT WAS RECONDITIONED AND SHIMED FOR BETTER THAN FACTORY PERFORMANCE (TIGHTER) 3 SERIES POSI
NEW 3.73 YUKON PERFORMANCE GEARS INSTALLED (BACKLASH SET AT .006) GM SPECS .005-.008
ALL NEW TIMKIN BEARINGS, NATIONAL SEALS, AND TORRINGTON AXLE BEARINGS INSTALLED AND READY FOR HARD CORE ACTION
ORIGINAL GM AXLES ALL CHECKED OUT SPLINES GREAT AND BEARING SURFACES EXCELLENT WITH ARP RACING 3" STUDS!
>>>> BONUS <<<<
ALL NEW BRAKES - INCLUDES NEW DRUMS, NEW BRAKE CYLINDERS, BRAKE SHOES, HARDWARE KIT, ORIGIANAL BRAKE LINES, NEW FLEX BRAKE CHASSIS HOSE, EVEN COMES WITH FACTORY ORIGINAL EMERGENCY BRAKE CABLES!!
THIS REAR IS SUPER SUPER CLEAN HOUSING!!
---- CONDITION ----
REAR IS TOTALLY REBUILT AND READY TO INSTALL, YOU WILL NEED TO FILL THE DIFF WITH GEAR LUBE AND POSI ADDITIVE, BLEED THE BRAKES, BRAKE IN THE GEARS AND GO HAVE FUN!
THIS REAR WAS AN ORIGINAL 3.42 1987 GN REAR POSI IF YOU ARE LOOKING TO GET IT TOTALLY BACK TO ORIGINAL I DO HAVE THESE ORIGINAL 1987 3.42 GEAR SET AND CAN INSTALL THEM BACK IN. THIS WAS TO BE A ORDERED ITEM WITH 3.73 FOR A CUSTOMER...THEN THEY JUST DISAPPEARED??? NOW IT IS UP ON EBAY, GOOD LUCK!
BOTH BACKING PLATES DO HAVE A HOLE IN EACH ONE FROM A PREVIOUS OWNER. LIKE THEY TRIED TO GET THE DRUM OFF OF SOMETHING??? ABOUT A THUMB SIZE HOLE ON EACH SIDE. TOO BAD, CAUSE THEY WERE REALLY CLEAN BACKING PLATES.
BUY IT NOW!!! FOR 1595.00 AND RECIEVE 1/2 OFF SHIPPING!!!
LOWER 48 STATES FOR SHIPPING DEAL.
330 659 7117
216 464 2313 weekdays 10 -5 est
ACTUAL GN REAR PICTURED YOU WILL RECEIVE
chesterkreetch
vega 10 bolt 8.5/ 12 bolt rear housing
Postby chesterkreetch » Sun Jun 22, 2008 2:19 pm
Hi I,m looking for a rear housing for my 72 vega I have a 383 FI 550/585 ft lbs torque mill...I would like to use the torque arm set up with the panhard bar as it see's road use more than track..I'm, going with the steve stohn adj. torque arm and same with lower control arms,panhhard bar for suspension...3.73 posi. gears with a 700r4 trans....any leads on anybody if not yourself.......thanks
Re: 1987 Grand National posi 3.73 rebuiblt rear with new brakes
Postby monzaz » Wed Jul 02, 2008 1:25 pm
were on it. Jim
Return to “Rear Ends and Parts”
Who is online
Users browsing this forum: No registered users and 1 guest
