SOLD---S10 2WD 3.42 POSI LARGE 8.5 GM EXTREME SS SONOMA HOT ROD
========= SOLD ================
NEW BUILD
S10 2WD 3.42 POSITRACTION LARGE 8.5 REAR END
10 BOLT CUSTOM 8.5 HOUSING BLASTED AND PAINTED
NEW YUKON PREMIUM 3.42 RING AND PINION
NEW EATON POSITRACTION UNIT 30 SPLINE
NEW MOSER ENGINEERING CUSTOM ALLOY 30 SPLINE AXLES
NEW BEARINGS AND SEAL THROUGH OUT THE ENTIRE REAR
REAR IS 53.75" - 54" TOTAL WIDTH
WHEEL BOLT PATTERN IS STOCK S10 ( 5 ON 4.75")
SPRING PERCH CENTER TO CENTER IS STOCK S10 (38" )
REAR END WILL ACCEPT STOCK DRUM OR DISC BRAKE SYSTEMS ( 2.75" BRAKE OFFSET IF YOUR BUYING A DISC BRAKE SYSTEM. )
HOUSING CENTER IS ORIGINAL GM AND DOES HAVE PITTING FROM BEING A NORTHERN HOUSING...IT IS BLASTED TO BARE METAL... COSMETIC NOT SHOW.
1675.00
WE CAN SHIP JUST NEED ZIP CODE
