i´m a young guy from germany and i´m new in this forum,i would need a lil help from you Jim and the other guys because i must swap the gears but i never make this job
I know the simplest way is to buy a Pinion Depth Set Up Tool maybe from Pro Form,but i haven´t the $$$$$$.
I´m not sure but if i measure the carrier bearing race only and Divide this number by two will this be the center position at the carrier?????Or must i measure the carrier bearing bore,too????
Best regards from Germany
I know my english is not the best but i hope you understand me???
