Wheel bearings
mercmarc
Wheel bearings
Post by mercmarc »
I'm thinking of replacing the axle bearing in my gm 8.5 diff. It has the super nova alloy axle. Do you recommend the one piece bearing with seal or the two piece?
Re: Wheel bearings
If you are talking about c-clip axle... ALWAYS use the 2 piece bearing and seal. NEVER the one piece as that is a REPAIR bearing... IT will leak.
Please confirm what axle type you have? Jim
mercmarc
Re: Wheel bearings
Post by mercmarc »
It's a c-clip axle. It's a ten bolt diff you built for my nova. It's the 30 spline.
mercmarc
Re: Wheel bearings
Post by mercmarc »
Is there a certain brand of bearing you recommend?
Re: Wheel bearings
Torrington is what GM used ...
5707 bearing and 8660s seal...
I think there is a kit number too. R1563TAV something like that.
