this is what i started with, 8.5 rear, eaton posi, richmond 3.23 ring and pinion, install kit from JDRACE.
old pinion inner bearing honed out with 052 shim,preload of 14in.lb.
244 pass. side carrier shim, 221 drive
.001 ring gear runout
backlash checked at 90deg. poss. .006 .008, .008, .005
takes slight pop of prybar to dislodge carrier
i think it looks good, but i need your opinion!
