Best brand of gears?
Re: Best brand of gears?
How does it feel with oil on the gears? Nice and smooth both ways? Looks pretty good to me. I just hate the fact that the backlash is so tight. BUT 2 step gears are suppose to be that tight...??? Looks good to me. Jim
My1979chevy
- Rookie Poster
Here is the final check of the pattern after pressing on the 'real' pinion bearing--
http://i1145.photobucket.com/albums/o50 ... 8fcffc.jpg
http://i1145.photobucket.com/albums/o50 ... 0af53f.jpg
Still with the .036 shim, and backlash was between .004 and .005.
Break in process going on now, so far they are quiet as stock. I did put a mag-hytec cover on with magnetic dipstick, and there are already some metal shavings on it after about 50 miles. Hoping its just break in/left over machining particles. I will watch it closely. After a 10 minute ride the temp is about 120 degrees with temp gun, on the pinion area.
Here is a pic of that number on the pinion. There was one on the ring gear too.
http://i1145.photobucket.com/albums/o50 ... 2e3e49.jpg
1979 malibu wagon
ZZ383/th350/8.5
ZZ383/th350/8.5
Looks pretty good. Boy now you got that pattern with .036 Not .010.
What a huge gap because the shims ride up on the pinion shaft huh?
I think you look good . You can tinker more if you like. Try to pt more fluid on the coast side and make the ring gear drag with a rag and spin the yoke. MAKE the ring and pinion torque as hard as you can. Then see what the pattern looks like. Jim
