.....and it comes like it had to come...
denis
Post by denis »
Jim....hope you remember-young guy from Germany
6 Years and many helpful advice later from you about bringing my weaky 7,5 Bolt rear back to life with new ring gear/posi and bearings for my 65 442 Olds...i know need again your advice about a stronger rear end because Drag Racing are know on the TO DO LIST....
But the situation is still the same...BIG DREAMS small BUDGET and it´s still very difficult to find any strong rear here in Germany which will hold if i use sticky tires on my heavy 442 convertible.
Maybe a can get a rear from a 1977 CHEVY EL CAMINO,is this rear a good starting point, don´t know which rear it is but i think a 8,5 is minimum what i need...what do you think.
best regards
Denis
denis
Re: .....and it comes like it had to come...
Post by denis »
here a pic from guy who sells them...
denis
Post by denis »
....at the same time post the threat i found another guy at ebay :
http://www.ebay.de/itm/Hinterachse-Chev ... 20d5ab45a8
"Posi" Rear from a 76 Big Block SS El Camino with light (Alum ?) driveshaft completely with brakes shoes and drums...
Let me know quickly ...it´s really a good deal.
denis
Post by denis »
denis wrote:....at the same time post the threat i found another guy at ebay :
..ohh and maybe do you have some measurement in comparison with my G-Body 7,5 GM 10 Bolt and original rear end like the wheel width and housing length (driveshaft).
Denis, The 1973-1977 rears will not bolt into your G-body rear...AT ALL. TOO wide by a lot. shocks are int he wrong spot and upper control arms are in the wrong spot Lower control arms in the wrong spot. This rear is about as far away as you can get to fitting a G-body OR a A-body 1964-1972 GM. Jim
What year is the car you are working on.
denis
Post by denis »
Car is 65 442olds
denis
Post by denis »
Jim, i assume a 8.2 wil not be a good starting point ,or is it possible to make them strong enought for my 65.
Found a guy how sell his 8.2 but its really expensive.
http://m.kleinanzeigen.ebay.de/s-anzeig ... /127331291
Its a 8.2 10 Bolt with eaton posi and 4:11 richmond gears from a 68 Chevelle.
I know it will fit but will time and money i investigate worth it?
Sorry for my english
Denis
Yah and it is in a Chevelle meaning it is a CHEVY 8.2 which is weaker than you already have.
You need a 12 bolt chevy from a 1965 66 67 chevelle
71 72 Skylark or cutlass 8.5
those would be good options for you.
We can build you a custom rear to fit your car but that ain't gonna be cheap. Shipping and all too. Jim
denis
Post by denis »
Jim,correct me if i'm wrong:
My 7, 5"10bolt are 58.5" lenght.
The 8, 2" which was stock, are 60.5"
And the rears from the 73-77 bodys are 62, 5"
So the best was to find a rear from A-body 68-72 but an 8.5", and change the wheels and backspacing.
Very difficult!!!!
Yes- remember width will vary some with in 1/8 inch shorter and wider
Yes I say this because 10 bolt 8.5 has ALOT of part available and is still being built today.
You can take 2013 gears and they will fit into 1971 cutlass or Skylark rear. Jim
denis
Post by denis »
Jim...need you help!!
It is a big difference in housing length, from my 7,5 10Bolt to a 8,5 or 8,2" ?
I ask because i want to calculate all cost,hope i must not change driveshaft length again :-(
regards from Germany
yes, aLL 8.5 WILL REQUIRE DRIVE SHAFT SHORTENING. sORRY MORE BAD NEWS. eVEN THE gn REAR which is 8.5 will require the drive shaft shortening. sorry for the caps. Jim
denis
Post by denis »
...Jim, please change the Rookie Status in Loser Status :roll:
denis
Post by denis »
what you are think about this 12 Bolt/ 28 Spline rear from a Buick Skylark 1969, i know its wider than the 64-67 rears but maybe a starting point?
http://kleinanzeigen.ebay.de/anzeigen/s ... -223-10511
http://www.jdrace.com/diff_id/12bABodyOlds.htm
What ratio is it? If it does not already have good gears PASS on it. Right now no one makes gears for these rears. It is a 12 bolt OLDS 10 bolt ring gear 28 spline boltr in axles. IT IS A good rear...BUT right now we do not know if ANY gears will be available for this rear again. :( JIm
Richmond was bought out by Motive gear and they have not made this gear in a year and a 1/2.
IF the rear has 3.08 3.23 3.42 3.90 then grab it. Jim
JIm
