12 bolt 57 narrowed 12 bolt
Postby monzaz » Thu Feb 15, 2007 2:48 pm
I have a customer trade in ...
specs
-12 bolt camaro 1967 -1969 housing
-Cut and re worked by Moser years ago
-housing was tweaked and required the brake flange weld to be offset abit. I double check the work and looks to be in order welding and trued up correct. Just looks a little sightly for my liking. Pictures soon.
-3.90 gear
-3 series Eaon factory posi
-Moser custom axles
all you need to do is weld on the perches that suite your application. over all width from backing plate to backing plate is 52" It is offset to fit a 1955-1957 chevy vehicle so it is best suite for that application.
email me if interested at mailto:mitschke454@windstream.net pictures will be available now upon request.
looking for 900.00 range but Negotiable
add up the parts and the labor and you will see that is a darn good price.
axle alone are 300.00 then a 12 bolt housing bare is 200.00 posi 3 seies even used is 200-300 on ebay, good gear set 100.00 used. then assemble it.
Return to “Rear Ends and Parts”
Users browsing this forum: No registered users and 2 guests
