12 BOLT S-10 2WD DIRECT BOLT IN 30 SPLINE 1995-2004 S-10 FLANGE END
WILL FIT EARLY MODELS BUT YOU WILL NEED TO USE newer S-10 95-04 BACKING PLATES.
MOSER CUSTOM ALLOY AXLES
2350.00 NEW EVERYTHING / NO BRAKES INCLUDED.
12 BOLT CHEVELLE 1964-1972 MOSER HOUSING DIRECT BOLT IN REPLACEMENT REAR 30 SPLINE 3.31 3.42 3.55 3.73 4.10 RATIOS
1350 YOKE FOR SUPER DUTY APPLICATIONS OR STOCK 1310 YOKE FOR EASY DIRECT BOLT IN FROM A 10 BOLT STOCK GM REAR
YUKON PREMIUM AXLES
2575.00
12 BOLT CAMNARO 1967 -1969 MULTI LEAF MOSER HOUSING DIRECT REPLACEMENT REAR END
YUKON PREMIUM POSI WITH YOUR CHOICE OF 3.31 3.42 3.55 3.73 4.10 RATIOS YUKON PREMIUM GEARS
1350 OR 1310 YOKE
ALLOY 1541H YUKON PREMIUM AXLES
2375.00
WE ALSO HAVE
1970 -1981 CAMARO REPLACEMENT 12 BOLT MOSER HOUSING REARS (2375.00)
1965-1967 CHEVY II / NOVA REAR ENDS 12 BOLTS (2375.00)
1978-1988 G-BODY (CUTLASS, MONTECARLO, MALIBU, GRAND PRIX ) CHASSIS 12 BOLT MOSER HOUSING REARENDS DIRECT FIT ALSO (2575.00)
just call or PM us here on the site.
Akron, Ohio
