12 bolt chevy rear end parts 10 chevy also HOLIDAY SPECIALS!!!
12 BOLT CHEVY YUKON DURA GRIP POSI
359.00 NEW IN THE BOX
10 BOLT CHEVY YUKON DURA GRIP POSI
12 BOLT CHEVY GEARS YUKON PREMIUM 3.42 3.73
175.00
10 BOLT CHEVY GEARS YUKON PREMIUM 3.55 3.73
175.00
12 BOLT 3.31 3.55 RATIOS YUKON PREMIUM GEARS
195.00
REBUILD KITS 12 BOLT OR 10 BOLT CHEVY
74.00
REBUILD KITS ARE VERY COMPLETE AND INCLUDE THE FOLLOWING PARTS:
2 carrier bearings and races
1 inner pinion bearing and race
1 outer pinion bearing and race
1 Pinion seal
1 pinion crush sleeve
1 pinion nut
1 rear inspection cover gasket
1 carrier pack of carrier shims
1 pinion pack of shims
1 marking compound and applicator brush
10 ring gear bolts
1 RED loctite vial
1 1 booklet to help you with your set-up pattern and torque specs.
AXLE BEARING AND SEAL KITS (2 BEARINGS AND 2 SEALS ) 29.00
SHIPPING TO BE DETERMINED ON WEIGHT AND ZIP CODE FROM 44286
HAPPY HOLIDAYS AND HOPE THIS HELPS FOR UNDER YOUR TREE!
J D
AKRON, OHIO
