custom g-body race street strip rearend 30 spline moser posi
Post by monzaz » Mon Oct 17, 2011 7:25 am
10 bolt 8.5 custom built street /strip/race
-10 bolt 8.5 custom built narrowed housing
-30 spline NEW eaton posi
-NEW 4.10 Yukon Performance gears
-NEW 30 spline MOSER ENGINEERING axles (5 4/34" GM wheel pattern)
-ALL new bearings and seals
-NEW urethane upper control arm bushings
-NEW upper double adjustable ICEMAN control arms custom built for J D Race
-NEW Aluminum race girdle support cover
-uses stock gm drum brakes from your 7.5 or 8.5 original gm rear
This rear will hold to what ever your gonna throw at it.
>>>>>>>>>>>>> $1695.00 <<<<<<<<<<<<<<<<<<
Pictures are of the actual rear end!!!!
MWireman
Re: custom g-body race street strip rearend 30 spline moser
Post by MWireman » Sun Sep 02, 2012 5:32 pm
Im curious, did u slide a smaller axle tube inside the old one or butt them together?
Post by monzaz » Mon Sep 03, 2012 6:01 pm
In side. Makes it much stronger there then a butt weld. You will have 1/4" tube in that area like a dana 60 . A narrowing bar still needs to be used to get these tubes straight to the bearing end from the carrier saddles.
