Turbo 400 yoke
Butcher455
Turbo 400 yoke
Post by Butcher455 » Wed Sep 16, 2015 12:33 pm
I have a driveshaft for a turbo 400 that is 3/4" too long. Is it possible to shorten the turbo 400 yoke instead of shortening the driveshaft. The yoke is 5 1/2" from center of u-joint to the end of the yoke. It takes the 1350 u-joint if that matters.
Thanks for any help.
Butcher
Re: Turbo 400 yoke
Post by monzaz » Tue Sep 29, 2015 5:53 am
You should not cut down your yoke. What rear did you replace your original rear with? If drive shaft is original it probably needs a balancing anyway and after they cut it they will do this.
