Used ring/pinion break in
Post by 67drake » Wed Jan 11, 2012 11:29 pm
The 8.5 I'm setting up will be using used GM gears. I'm curious if the break in procedure is for heat cycling or gear mesh break in? If heat cycling, I would think I can just set it up and go? Any break in required when setting up used ring/pinion?
Thanks.
Re: Used ring/pinion break in
Post by monzaz » Thu Jan 12, 2012 10:35 pm
If they are good used...NO Break in is required. Hammer down. :) JIm
