id rear ends
monzabug350
id rear ends
I need help identifying which rear end would be best for my Monza. Its a 79 2+2,305-auto,I found 3 which are RWD.2WD.I copied the numbers off the housings. 97s-10 4cyl-5spd-2604141-no posi-large round collar around u-joint-9" drums.vin:1gcss1441yk242382. 88 s-10-v6-5spd-d104 8(9) 14030352 n-non posi-243mm drums-vin:1gc8514roj2215191.08 GMC Sierra s-15-v6 auto.L067 14030352 n 9" drums. No vin,dash removed.Ihave untill Wed,May12, to pull them or theay go into the crusher. Iposted this info on the H-body website,got some good input but one reply said to contact you as you are " the diff man". Thank you for your time.
Re: id rear ends
Just answered that on the H-body forum.
The one I am not sure of is the sierra S-15...Is this CORRECT? Is this a 1/2 ton rear or S-10 type rear? Do you mean Sonoma??? Not sierra.??
The large collar would be a harmonic vibration balancer... That is really NOT needed. If you can find a different yoke it would be better NOT to have that for better performance.
Are you trying to BOLT these rear directly into the monza OR are you trying to use the parts from them?
monzabug350
Re:which rear end
the s-15 is/was a long bed,crew cab(2dr)the plate on the body said s-15 sierra LX,could be a Sonoma,drive shaft gone.I was thinking of putting this one in the Monza,if that is not worth it,Ill probably use what I can for the one in the car(no I havent checked which one is in the car yet)I opened the diff this AM,and had the following #:Ring Gear:GM-14092111-11:41-7 5/8.Pinion: l-11:41 GM.Carrier:7139,and a big#3.Axles:28spline-24 5/16 from flange to tip.Housing width:48"(?)B/P to B/P.can you tell me what ratio?Is this a 3 series carrier? The ring/pinion pattern is a gray/pitted pattern but no shinny metal in the lube.It looks as if the pattern was set too deep or this truck did a lot of heavy hauling. I hope this info will help in ID what I have and if it will be worth while using. Thanks in advance for your help!
Re: id rear ends
The 11 41 is the tooth count of the ring and the pinion That is 3.73 rear ratio
24 5/16" ??? can not be correct. Remeasure.
48" backing plate to backing plate will be a stock 2wd s-10 which should fit under your monza nicely.
axle shaft lengthshould be in the 26 3/4" width for this rear.
