Spring perch
Spring perch
Do you guys or anyone sell the spring perch that is welded to the axle tube for a 1970 Gm A-body (Oldsmobile) I have a rear bet they seem a bit rusty and wanted to replace.
Re: Spring perch
They will not be exact as GM as on the 1970 -1981 they were slightly different from 1968 69 models They were mounts that actually lowered the chassis another 1/2" So others would raise your chassis a 1/2" than stock.
We might have some good used perches removed from a MODIFIED REAR DONE IN THE PAST.
