12 bolt b body
Lowrider
12 bolt b body
Postby Lowrider » Wed Jan 25, 2017 1:51 am
will a 12 bolt 68 to 70 b body diff fit into a a body 60 to 70
Re: 12 bolt b body
Postby monzaz » Fri Jan 27, 2017 8:04 pm
Nope, Not even remotely close. Sorry.
65-70 B-Body Impala Caprice Biscayne rear will only fit 65-70 ONLY
1965-1972 A body rears all interchange Chevelle ,El Camino, Skylark, GTO, LeMans, Tempes,t Cutlass, F85 etc. ALL interchange.
1973 -1977 A-body all have to stay together also
Then there is the 1978 -1988 G-body they stay together also.
So those are your different chassis.
F-body 67-69 alone with Nova are all Leaf spring.
You need the 4 link control arm rears from 1965-1972 GM A body chassis. That is it.
Any reason you have to have a 12 bolt? If you are just hanging on the street and only a few track blasts a year IA properly build 10 bolt will do the job even under big block power. TOO much track and even a stock 12 bolt Chevy rear will blow a spider gear. Spider gears are the weak link in ALL differentials ... The street can not hold big torque so the tire end up just spinning which does not make a binding force on the drive like like a stick track and stick tires etc.
Just some info for you to think about.
J D RAce
Lowrider
Re: 12 bolt b body
Postby Lowrider » Sun Jan 29, 2017 12:12 am
Thanks its just I can get a 12 bolt b body complete diff and I just want to see if it would fit into my 68 GTO, It has 4 trailing arms and it is 58" from flange to flange
Re: 12 bolt b body
Postby monzaz » Mon Jan 30, 2017 5:55 pm
No Way No How... you needa 55.25 flange to flange and a over all drum to drum of 61"
Users browsing this forum: No registered users and 2 guests
