BOP possibilities
Re: BOP possibilities
Post by monzaz » Fri Mar 11, 2016 1:15 am
ALL ON you, you want a nice ride with some deflection etc RUBBER. If you want a tight ride feeling the road more than Urethane.
I have all Urethane on the SS 1971 Monte Carlo. If you hit a pretty good chuck hole it will jar the crap out of you and hop the rear too.
stevieray
Post by stevieray » Tue Mar 15, 2016 6:24 pm
Finally got back to it. The original pinion washer was 43. I replaced with a 40 thousandths service washer. Attached are the results. Backlash is still around 8 thousandth.
How does it look??? The service washers in my kit will only allow me to go down by 10 thousands (thinnest) if I need to reduce more.
Steve
Post by monzaz » Tue Mar 15, 2016 10:42 pm
Weird it looks too shallow on the coast side and too deep on the drive side. .040 looked better.
Open the backlash up to .010
stevieray
Post by stevieray » Fri Mar 18, 2016 5:10 am
Am I there yet?
This is with pinion washer set at 34 thousandths and 7 thousandths backlash.
Thanks,
Steve
Post by monzaz » Fri Mar 18, 2016 9:25 am
Rubber or urethane
All on you and the ride you want. Rubber will give you factory ride and less feel of bumps.... Urathane wil lcontrol the torque bettr but you will feel the road more in sharp bumps. Jim
Post by monzaz » Fri Mar 18, 2016 9:26 am
Pattern, I think you have it. How does it feel ...Close your eye and just spin it both ways... does it feel equally smooth? Looks good as a used gear can. Jim
See how the pattern kind of covers the whole tooth. It is light everywhere not a super hard pattern swipe as much at the top or bottom area.
Now run it and just do a short run to start in case anything might not have been assemble correctly...Work your way into confidence. give a few days progressively getting longer and harder. check for leaks and have fun this summer. :)
stevieray
Post by stevieray » Fri Mar 18, 2016 9:51 am
Thanks for all of your help!
Steve 8)
Post by monzaz » Sat Mar 19, 2016 1:06 am
Can you see what I am seeing? Just trying to help everyone see the pattern how spread out it is over the whole tooth and feel the smoothness of the spin. You can see from the other pattern how hard it was hitting in just one area. NOW sometimes that can be all you can do with some gear sets that have issues.... yours should be pretty good. Will see and hear. :) Jim
hojoos
Post by hojoos » Thu Feb 20, 2020 2:08 pm
You can not NORMALLY swap gears from different size rears. WE can retro fit 3.08 chevy gears into the BOP 8.2 rear it will require some trick parts... Need a 8.2 CHEVY yoke... then we have a custom steel bushing made for increasing the yokes seal diameter to match the BOP seal ID lip . You will also need a totally different carrier series than the 2.93 one. So as you can see it is just not as easy as bolting it right in.
Post by monzaz » Sun Mar 01, 2020 7:43 pm
Rubber will always give you a better ride as to NOT hear or feel the road bumps and noise. Urathane will make the car handle better BUT the loss will be rougher ride will feel the bumps more.
Urethane from what we have had will almost last for ever...lol
1971 Monte SS has had urethane in for 32 years feels the same from 30 years ago.
Post by monzaz » Tue May 05, 2020 10:46 pm
