Site Logo
www.jdrace.com
JD Race and Restoration
It is currently Fri Sep 10, 2010 11:24 am
Post new topic Reply to topic  [ 4 posts ]
Author Message
 Post subject: Sway bar quest...G-BODY-A-BODY
PostPosted: Mon Feb 08, 2010 6:09 am
Offline
Hello Jim and Guys...
Anyone know what rear sway bar must i use if i bold a weaky G-Body 7,5" 10 bolt rear in a A-Body car (oldsmobile 65),a A-Body or G-Body sway bar???
I know that many G-body guys use A-body 10 or 12 Bolt rears but which sway be he used,i don´t know ..maybe you guys have any advice?
The rear are installed with the factory A-body rear arms....and Jim,she´s still alive!!!
Regards from Germany
denis
Top
 Profile
 Post subject: Re: Sway bar quest...G-BODY-A-BODY
PostPosted: Thu Feb 11, 2010 7:36 am
Offline
Well that depends on the control arms...If they have sway bar access holes I would have to say a-body sway bar. But you also need to recognize if you had to pull the arms in and if you did then the G-body sway bar will work if the proper holes are drilled in the a-body control arms.
Do you have an inside measurement where the sway bar is suppose to go? Jim
Top
 Profile
PostPosted: Fri Feb 26, 2010 4:01 am
Offline
hello Jim.........
problem solved,i need a A-body bar........
thanks
Denis
Top
 Profile
PostPosted: Sat Feb 27, 2010 8:55 am
Offline
So your installing a G-body in a A-body 65-72 chassis? Man how depressing you have to go down to a 7.5 rear.
How are you getting the upper to fit? Seems like the arms will not be long enough causing the pinion angle to be WAY off and the binding of the suspenion. ??? Let me know Pictures etc. Jim
Top
 Profile
Display posts from previous:  Sort by
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
cron
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
Template made by DEVPPL Flash Games
